Telecom box design
Telecom box design
Hi all,
My company was about to design telecom enclosures for power distribution unit & I am looking for info for it. Is there any guidelines or practical tips for this, such as structural & water/ dust protection requirements (NEMA 4X)?
engmechs
engmechs
RE: Telecom box design
Keith Cress
engmechs
http:
<tg>
http:
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
engmechs
Tunalover
NEMA4X and IP68 are sort of equivalent. If your box meets one, it probably meets the other one.
I do not have a NEMA reference in front of me, but I believe NEMA4X is something like a 64GPM salt water through a 1" hose for half an hour with minimal water inside the box, and no corrosion. You should not be able to reach into the box with a 1/4" bar and touch live electronics.
The IP68 reference on my wall specifies complete dust protection, protection against continuous immersion, and you should not be able to contact anything hazardous with anything 1mm diameter. My reference says nothing about the depth of immersion, but I think it is 2m. You are allowed a little fluid penetration.
JHG
engmech
