Hole gage distance chart
I'm looking for a chart which contains gage distances for angles and beams and the such, Can someone help a guy out? Thanks.
RE: Hole gage distance chart
AISC ASD Manual of Steel Construction should have those bolt gage charts.
If you don't have the manual, there is a spreadsheet under http://www.pipingdesigners.com/Tools.htm
Go to the subject "fittings", then click "Pipe and vessel data". That spreadsheet has tabs for angle, wide flange beams, etc. that contains data like bolt gages.
