Extruded hole cut at an angle? help!
Hello all.
I am a newbie to Solidworks. I have figured out alot on my own like making simple cylindrical parts using revolved base.
I have searched all through the help sections and I have not figured out how to make a hole at an angle to the centerline of a part.
 Again I am using the revolved base feature and I am creating round parts. I want to make holes going out from top center of the part going  through the sides of the part at an angle to the centerline.
I can make holes all day long all the way through the part at 0' to the centerline, but I want to make holes coming out at angles like 30' or 40'.
Make sense?
Any help would be appreciated.
thx
Matt
RE: Extruded hole cut at an angle? help!
You need to make a new plane at an angle and add the hole to the new plane. Look up angles in help and go through the turorials.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-08-07)
How do I create an angled hole using the Hole Wizard  FAQ559-1156
How Do I Use The Hole Wizard On A Cylindrical Face?  FAQ559-1150
cheers
SW07-SP3.1
SW06-SP5.1
Thx everyone!
I just figured it out !!(with your help of couse!!
thx
Matt
