Derating SOW Cable
Derating SOW Cable
Does anyone know, in general what NEC section (table) best describes how to derate SOW type cable. I am unable to verify voltage drop calcs. The application is for (temporary) power disto from smaller portable generators (15kw). The cord reels are specified with 200' SOW cable, 3wire+G #10AWG "split" single phase, 240V. The continuous load is one 1.5 hp 230V motor (10A), and two 750W-120V lights, one per leg. When we say 10A @240V single phase, we mean 10A per wire correct? Ambient 30degC. Just looking for less than 5% on the 230V motor. No electronics so the overall circuit VD doesn't concern me. Would anyone be able to calc if they know? I find about 8.1V with 16.25A load. Say the neutral caried both 750W lights, is it necessary to derate further if it carries a net current? Thanks, JD (EIT).
RE: Derating SOW Cable
htt
