range of turndown ratio for absorber
dear gents
i would like to know what is the range of turndown ratio for absorber, because normal feed gas rate for liquefied gas plant is about 700KNm/h3 with amine circualation about 90 M3/h but on start up we have always off-spec co2 in the gas (grater than 100 ppm )that happens with 125 KNm3/h feed, absorber is trayed one 20 bubble cap trays
RE: range of turndown ratio for absorber
Please read FAQ731-376, particularly item 5, first. Then, make up your mind in which forum to post. Thank you.
Cheers,
Joerd
