HELPPP!!!
HELPPP!!!
HELPPP!!!
hello everyone. I am doing a cad drawing that has lot parcels. now if there a way to auto number them. The lots are basically sqaure boxes. If there a feature that would allow you to click the box and autonumber the lots 1-200?
please help. thanx you
RE: HELPPP!!!
What version of Autocad are you using.
The express tools that come with AutoCad has an Auto numbering command, it is fairly useful.
RE: HELPPP!!!
autodesk autocad 2006
RE: HELPPP!!!
Did you install the Express Tools when you installed Autocad, if you did then you should be all set.
RE: HELPPP!!!
yes i did install express tools, but what do i do to number the lots?
RE: HELPPP!!!
The command is something like "tcount".  Or look through the Express Tools menu, maybe under tools.
RE: HELPPP!!!
If all of the lots are drawn just simply copy a piece of text into the correct place on the first one.
When you are happy that you have the text in the correct place with the correct font and size etc. simply copy it to every "lot" that you wish to auto number.
Next you need to use the Automatic text Numbering from the Express pull down menu.
Select each piece of text that you want to be in the number sequence and enter (note. if you select them in order the numbering can follow the same order)
Next you will be asked for which order to number in. If you use select_order that will number in the order you picked them.
Then you can set the starting number followed by the increment.
Then finally you can select how you wanyt the numbering, i.e as a suffix or prefix or overwrite the complete text with the new number.
Hope that helps. have a play and see what you get. I have used it a lot and it is quite useful.
There may be some way of automating this with some form of Lisp routine but I have never needed more than express tools can give.
RE: HELPPP!!!
CarlB is correct, the command from the Express menu is TCOUNT
RE: HELPPP!!!
looks like it is tcount. but when i click on the lot it says no objects selected
RE: HELPPP!!!
Read davsy's detailed description.  First copy the text, then run "tcount".
RE: HELPPP!!!
omg thanx you all soo much. It works. Is there a command that would center all the number in the lots?
RE: HELPPP!!!
Make sure you are only selecting text and no other objects when you use the Tcount command.
