IEC Short Circuit Standard for FPSO
Hi to all,
I just want to collect some ideas and expert recommendation to justify which IEC standard to use for the calculation of short circuit currents for FPSO (Floating Production, Storage and Offloading Vessel) power system; IEC60909 or IEC61363?
My experience we use IEC61363 for marine installation like LNG Carriers but one FPSO used IEC60909. Please advise!
Thanks and regards to all,
Phil
RE: IEC Short Circuit Standard for FPSO
In my opinion, IEC 60909 is the general standard. When particular conditions apply, such as marine, you should use IEC 61363-1 for short circuit calculations. The simple fact that one has used 60909 can be misleading because the standard rating of equipment may be well above the calculated requirement. Still it is unorthodox.
Regards.
The 909 can not be applied for marine plants, as explained in the first paragraphs.
