CO2 vertical storage tank design
I have to design a storage tank containnig LIQUID CO2,
to ASME sect VIII div.1 ,MAWP 350psi, MDMT -40 deg.F, 8'dia., 26'H.Matl'S: SA-612,
I started to get physical properties of CO2,in order to determine the optimum operating (Temp., pressure).and reading some technical documents related to Cryogenic bulk storage.
I am using Compress for calculations.
my questions :
1- why we used to incorporate a vaccum jacket with this kind of tank ? why vaccum?
2- How we calculate the insulation?
3- is it really necessary to have a refrigeration system inside the tank, and how we design it?
4- for all accessoires ie: Nozzles, instruments , even lifting lugs, legs, etc.., Why are they in S.S material?
5- is it required special inspection during fabrication, I mean for instance: black light for detecting oil, durty surf., ..( as service oxygen)
Every ideas, tips,advises are very appreciated.
Thank you for your help.
RE: CO2 vertical storage tank design
Because vacuum is a good insulator.
http://www.vacuumlab.com/Articles/VacLab34.pdf
Apply the theory of heat transfer.
Some liquid carbon dioxide changes back to the gaseous state because of heat leakage into the tank. You need a refrigeration system to condense the gas back to liquid. To design the refrigeration system, you need to know the heat leakage and you need to know something about refrigeration. This forum is the not the place to learn such a broad subject.
Because some stainless steel materials have properties that are suitable for low temperature service.
http://www.azom.com/details.asp?ArticleID=1176
Here are some suggested reading materials for you...
http://www.taylorwharton.com/Pages/Literature/Tech%20Man%20pdf/Bulk/bt-235.pdf
http://www.iso.org/iso/en/commcentre/isobulletin/articles/2003/pdf/cryogenic03-12.pdf
Good luck.
I don't think this is a usual NDE during the fabrication of a cryogenic vessel. Maybe some of the inspection experts in this forum can answer this. I do know that "black light test" is one of the inspection techniques to check for oil or grease contamination. But this check has something to do with surface preparation prior to coating of the vessel.
here's another reading matl for you...
http://www.ascoco2.com/file/2/ct_187_ctDownload1.pdf
1310laurent (Mechanical)
Liquid Carbon Dioxide (CO2)Storage Tank Specifications
http://www.uigi.com/co2tanks.html
Addtional informaton search google: Liquid Carbon Dioxide (CO2)Storage
Steve
