Square Helix
Square Helix
Does anyone know how to make a square (with fileted corners) helix? The tool will only let me use a circle sketch as a basis.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Square Helix
http://www
You will need a membership to see the tutorial, but it is free to register.
Hope this helps!
Best Regards,
Jon Knabenschuh
Gemini CAD Solutions
http://www.geminicadworks.com
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP5.0
RE: Square Helix
I'll head over there now.
RE: Square Helix
Also in the tutorial CADGemini posted above, steps 15 to 20 can be replaced by using the Intersection Curve tool and selecting the surface bodies. The Composite Curve can then be created by selecting the Intersection Curve sketch rather than all the individual entities as suggested.
http:
SW07-SP3.1
SW06-SP5.1
RE: Square Helix
http://www.savefile.com/files/615579
SW07-SP3.1
SW06-SP5.1
RE: Square Helix
Download "Hinge.zip"
The hinge assembly includes a conic torsion spring. You could use as similar method to create a "squared" spring.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
