I need some help with macro programming.
Hello i have some problems with macro programming
I have this .prg file which changes some colors in drafting.
This .prg worked in I-DEAS Master Series 8 but it doesn't work in I-DEAS 12 NX.
c:*****************************************************************
c:* *
c:* Program za korekcijo barve crt *
c:* *
c:
c: Program pretvarja barve crt po opravljenem prenosu iz modelerja
c:
# geomcolor = 1 ;rdeca
# hidecolor = 9 ;Lt blue
# notecolor = 3 ;rumena
# dimcolor = 3 ;rumena
c:
c:
# inquire ent max (entmax)
# inquire view number (currentview)
c:
# for i = 38 to entmax do
# Inquire Entity Characteristics ( i, , , , layer, , , , , )
# if (layer eq 204) then goto spremenicrto1
# if (layer eq 205) then goto spremenicrto2
# if (layer eq 206) then goto spremenicrto2
# if (layer eq 200) then goto skrijdim1
c:
# setfinished:
# next
# delete all ;delete all of the variables from
e: end ;the database and end
c:
# spremenicrto1:
# Modify Entity Characteristics ( i, , , , geomcolor, )
# goto setfinished
# spremenicrto2:
# Modify Entity Characteristics ( i, , , , hidecolor, )
# goto setfinished
# skrijdim1:
# Modify Entity Characteristics ( i,1, , , , )
# goto setfinished
When i apply this .prg in I-DEAS 12 NX i get this error:
Error, line 31: cannot execute 'NEXT', no matching 'FOR'
The like 31 is:
# next
Any tip maybe how to fix this :) ?
c:* *
c:* *
c:
c:
c:
c:
c:
c:
# setfinished:
# next
c:
# spremenicrto1:
# goto setfinished
# spremenicrto2:
# goto setfinished
# skrijdim1:
# goto setfinished
The like 31 is:
# next
RE: I need some help with macro programming.
c:
c:
# if (layer eq 204) then Modify Entity Characteristics ( i, , , , geomcolor, )
# if (layer eq 205) then Modify Entity Characteristics ( i, , , , hidecolor, )
# if (layer eq 206) then Modify Entity Characteristics ( i, , , , hidecolor, )
# if (layer eq 200) then Modify Entity Characteristics ( i,1, , , , )
c:
# next
c:
Hope this helps,
Mike
