oxygen cleaning chemicals
i want information regarding the mainteance of liquid oxygen carrying tanks, i need information espescially about oxygen cleaning chemicals. can u suggest a source. pramod
RE: oxygen cleaning chemicals
Pramod:
Your question isn't very clear to me. Do you want to remove small amounts of residual oxygen from empty tanks that were used for transporting oxygen?
If that is what you meant, then you might consider sodium sulfite or sodium bisulfite or hydrazine ... all of which are used to remove small amounts of oxygen from boiler feedwaters.  It may be applicable for your needs.
Milton Beychok
mbeychok@home.com
Air Pollution Dispersion Modeling
Visit my website to learn about "Fundamentals of Stack Gas Dispersion", a most comprehensive book on dispersion modeling of continuous, buoyant air pollution plumes. The site has published peer reviews and the complete Table of Contents.
If you are looking to clean equipment for oxygen service I refer you to publication G-4.1 published by the Conmpressed Gas Association (CGA). CGA is located in Arlington, Virginia and their phone number is 703-412-0900.
