Dimensioning
Dimensioning
Dimensioning
Hello, are there anyway to change all the dimensions from mm to cm without changing each one manually? Thank you in advance.
RE: Dimensioning
Go to Document Properties, Units, Change Length units to centimeter.
Sylvia
RE: Dimensioning
If you've already dimensioned everything, select all the dimensions (LMB while dragging right to left). In the 'Dimensions' property dialogue, choose 'more properties' at the bottom, then choose 'dimensions'. Under 'units', deselect 'use document's units', click 'units' and then select your new units. Click 'Ok', then 'Apply'.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
RE: Dimensioning
There is also a filter (f5) so you can easily window select all the dimensions to change them together.
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP2.2 on WinXP SP2
RE: Dimensioning
alright, thanks a lot!
RE: Dimensioning
actually, are there any shortcut to change all the dimensions double of what it is? or will that require to be manually changed? thanks!
RE: Dimensioning
double in terms of dimensions. thank you, i will try out that macro.
RE: Dimensioning
CBL, I haven't used the function, but what about the Scale Feature?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
RE: Dimensioning
fcsuper ... The scale feature is literally that ... a feature, and will show up as such in the FM tree. Its main/original use (I believe) is to enlarge a component to allow for shrinkage of injection moulded or similar parts, and can be applied to individual, or groups of, dimensions. Like other features it can be rolled back or suppressed.
The ModelRescaler macro simply enlarges the component. It does not appear as a feature ... it changes the actual part. If the part needs to be changed back after its use, the macro has to be re-run to apply a suitable factor.
cheers
SW07-SP3.1
SW06-SP5.1
