COMPRESS 3D working with ACE Structural Engineering Application LLC
Tom
Is it possable for COMPRESS xml file extension to work with 3D ACE Structural Engineering Application LLC
http://www.acesea.com/acefpl.html
Caged Ladder, Circular Platform, Stairs,  Handrial, Slab Plate Grating, Flexible Handrail Layout, Vertical Vessel Fdn, Library ASCII Export, Library Compression, Library Units Converter.
Also, for the CODEWARE COMPRESS software HEADS, CYLINDER, DISHED COVER ELLIPOSIDA HEAD F&D HEADS FLANGES, HEMI HEAD JAACKET VESSEL, NOZZLE FLANGES, to ues 3D ACE Structural Engineering Application LLC
Steve
RE: COMPRESS 3D working with ACE Structural Engineering Application LLC
Steve, Anyone can use the COMPRESS "xml" output to use the COMPRESS vessel information. Talk to ACE about programming this interface, or your local IT gurus. Information can be found at http://www.codeware.com/support/xml.html
Some companies producing third party applications that use the COMPRESS output are shown at  http://www.codeware.com/software/addonpartners.html
  Tom Barsh
  Codeware Technical Support
