External Bolting for NACE Equipment
I'm Xeros.
The equipment is in NACE Service and this equipment is inulated.
Is External Bolting applied NACE requirement?
I heard that wetted part must be applied NACE requirement but not-wetted part need not.
However, if the leakage occur in flange!!!!!
The NACE fluid could be contact with bolting material because leakage occured and equipment was in insulated condition.
In this case, shall the bolting material be applied the NACE requirement???
I appriciate to get your opinions and reference if present.
I'm Xeros.
RE: External Bolting for NACE Equipment
Steve Jones
http://www.pdo.co.om/pdo/
Thomas Eun
At one plant they even stress relieved all the 2" Angle iron used for the decking and hand rails. I under stand they too the whole block on a 2650 HP intergal engine and ran it through the oven....
