Bend And Twist Feature help needed
I need to flex and twist a sheet metal channel for a helix conveyor I am designing. The geometry needs to also automatically give me the flat pattern of the channel after the solid part is drawn.
How can get the part to retain both the bend feature and the twist feature at the same time and also allow Solidworks to be able to create the flat pattern?
Thanks in advance
Deon7
Thanks in advance
Deon7
RE: Bend And Twist Feature help needed
So, one config to show the finished bent and twisted part, and another to show the flat.
SW07-SP3.1
SW06-SP5.1
again, thanks in advance.
Deon7
htt
Which version are you using?
SW07-SP3.1
SW06-SP5.1
AND LOOKING FOR SW07
