MATLAB R2006b Compiler v.4.4 generated standalone application problem
I generated a standalone application from my m-files using Matlab r2006b. The compiler version is 4.4. The command I used is:
mcc -m [list of m-files]
I get an .exe file, which runs fine on the computer I used to compile the code. But, it does not run on a different machine. I get an error message saying mclmcrrt75.dll was not found. Can anyone give me a clue to what I may be doing wrong and how I can correct this problem? Thanks.
-OK
RE: MATLAB R2006b Compiler v.4.4 generated standalone application problem
Did you package the MATLAB Component Runtime (MCR) with the executable and supporting files when you changed computers? If not, it needs to be included.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Thanks for the super fast response xnuke. I am not sure how to do the packaging with MCR. I did put the CTF file in the same directory from where I ran the application, but that did not help. I knew it had sonmething to do with MCR, but I thought MCR is not required if the other machine has MATLAB as well. Can you please give me a hint of what I can do? YOur help is greatly appreciated.
-OK
