Copy a line around an arc
Good afternoon, I am trying to make the simple face of a guage and I need to make a line, coming off of an arc and I need to copy it 16 times evenly around the acr. I tried to use circular pattern but it did not like the line. Is there any way of doing this? Thank you in advance for any assistance.
RE: Copy a line around an arc
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-26-07)
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Chris
AutoCAD 06
RFUS
SW07-SP3.1
SW06-SP5.1
FAQ559-1100
Chris
AutoCAD 06
then like I said above, in a new sketch convert this line and the point you want to rotate it around from your previous sketch. Select and delete the instances you don't want
Jeff Mowry
