Welding then forming 409SS problems
                    Weld seam cracks after roll forming a flange.
                    Process: Rolling a cylindrical tank with 14 ga 409SS sheet and
                    using SAW for the butt weld seam.  Filler is ER309LSI and flux is
                    ST-100.  After the seam weld, a .4" deep flange (rough cross
                    section below) is roll formed on the top edge of the tank.  The
                    weld is so brittle it cracks at the stressed corners.  I am getting
                    mixed info on pre- and post-weld heating.  One says to use low
                    heat input during welding and form at room temp without
                    annealing.  Another expert suggested pre- and post-weld
                    treatment.  If heat treatment is recommended, can heating with a
                    dull grinder be effective?  Any other suggestions?  It would be
                    nice if a ductile filler for 409 and 304 could be found.  Thanks in
                    advance.  SCOTT
                                                     |____
                                                      ____|
RE: Welding then forming 409SS problems
We use 308 or 309 austenitic grade welding wire to successfully join our exhaust components which are either 409, 304 stainless steel or ACMS.  I suggest you may have residual stresses introduced in your part by the roll forming operation and it may be necessary to stress relieve the part before welding, but not with a dull grinder.
No doubt your cracks are being caused by forming stresses from the flanging operation,  but I'd also try using a different weld filler material.  For example, try a ferritic filler wire with Cb stabilization.  It'll help you avoid intergranular corrosion if the end product is ever exposed to salt.
