ANSI/NFPA Fluid Cylinder Standards
I would like to put in RFQ to a list of my vendors for a ANSI/NFPA standard cylinder. What standard should I buy so that I will know the proper way to spec the cylinders. Specifically I would like to know how to generate a part number for a standard NFPA cylinder. (If that is possible. Thanks)
RE: ANSI/NFPA Fluid Cylinder Standards
http://www.lwhydramotion.com/
http://www.peninsularcylinders.com/ca_nfpa.htm
http://w
http://www.nfpa.com/Pdf/T3_6_64-1998.pdf
I guess that is why God created Google.
