Downloading Die Springs
Is there a Website I can go to Download SolidWorks versions of Dayton Maxlife Die Springs?
RE: Downloading Die Springs
I don't know of one ... but do you really need a fully modelled spring? Would a correctly sized cylinder with a large thread texture suffice?
cheers
SW07-SP3.1
SW06-SP5.1
Here is a link to the die spring file I have created.  I just morph it into whatever I need.
http://visualvault.auerprecision.com/ViewFile.aspx?DlID=6eac1926-039a-436a-8133-1b3ddbf242ee
The last feature, when you click on it you can change the length of the spring.  It is tied to an equation that updates.  I use configurations for free length, die open, die closed, etc.
When I need a different spring I go into the sketches and make changes for what I need.
They aren't perfect, but are good enough to drive the design and populate a BOM.
Anna Wood
SW 2007 SP2.2, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
