Recommended velocity for Propne
I would appreciate the help. I am trying to find the recommended pipe velocity for propane.
Thanks!
Thanks!
RE: Recommended velocity for Propne
Are you trying to work backwards from a velcoity and then size a line?
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
I'm assuming that just like chilled water, there is a recommended velocity/pressure drop that is typically used when sizing pipe to simplify the process. This velocity is typically related to errosion of pipe, water hammer, etc.
You might as well get trained up on butane, propane, and LPGs handling a bit, so have a look at the DIY manuals at Corken Pumps. There's everything you never did want to know about it here,
http://www.corken.com/publications/training.html
BigInch
