Impact test requirment of SA334 Gr.6
Dear All,
When tube material is as belows, is this materail required impact test?
SA334 Gr.6==> O.D 25.4mm * Thick 2.769mm
SA334 Gr.6==> O.D 31.8mm * Thick 2.769mm
If required the impact test, Please let me know how to get the sub size of specimen.
RE: Impact test requirment of SA334 Gr.6
Could you please provide more detail as to the application of these tubes? IS this for a heat exchanger, boiler, pressure vessel?
Aravind Sujay
Mike
