Is there a way to batch export to iges?
I dont want to sit here and convert each file manually is there any way to batch convert a project or file to iges automatically?
Thanks alot I appreciate the help
RE: Is there a way to batch export to iges?
probatch
Thanks for getting me started, I didnt even know I had pro/batch. I am having some problems getting it to work though. Basically only way i could figure out how to open it is in the start run command type in pro_batch. Not sure how to actually get it to do something
You can run from windows explorer....it's a little easier if you copy the batch file to the folder that you have all your parts in..either way
in the Pro/Engineer command field... you want what's in your target of your shortcut that runs proe
you grab your files with the browser, set the action you want ..convert to iges ...then you save the batch file under a name...  myfiles.bat in the batchfile field
then hit the clock icon...go get coffee smile
when you copy the target info from the proe shortcut properties ...don't grab the quotes
the bat file you name will look something like this
-iges -object C:\wf_config\acad_rend\test_fea.prt.3
pretty sure that has to end with a .bat extension
it will generate a log and a list when complete, so you can review what got done
