Leader not needed
Leader not needed
Leader not needed
How can I remove the leader added by SW when I insert a block, using VB?
Andrew
RE: Leader not needed
What version of SW are you using?
I think that the leader option is defined in the block definition. In SW2001+, the leader option is presented in the Property Manager when you insert the block.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Forgot this. If you want to remove the leader from a block that is already inserted, just right-click the block and the toggle is available in the Properties of the object.
dsi,
I know that. What I do is I insert a block attached to a drawing view using a VB program. I would like the block to be inserted without the leader added automatically by SW or use some API commands to remove it after insertion. I couldn't find anything helpful in the SW API help.
Andrew
Sorry about that.
That should be controlled by the Annotation::SetLeader2 method. The Annotation Object is a level above the CustomSymbol Object.
I'm trying to use the following code to eliminate the leader added by SW:
Private Sub cmdXXXX_Click()
Part.InsertCustomSymbol "I:\Solid Works Lib\ATI-SW Data\Mark.sldsym"
Set AView = Part.ActiveView
Set MarkX = AView.GetFirstCustomSymbol
Set XXXXAnn = MarkX.GetAnnotation
junk = XXXXAnn.SetLeader2(0, 0, 0, 0, 0, 0)
Part.ClearSelection
End Sub
I get the following error at line:
Set MarkX=AView.GetFirstCustomSymbol
"Object doesn't support this property or method"
and I don't understand why?
Andrew
Part.ClearSelection
End Sub
Andrew
