Source of supply - Hydraulic hoses
I'm looking for a supplier of hydraulic hose assemblies that are a bit unusual:
- working pressure 5500 psi, burst pressure 4x
- 3/4" nominal
- nominal o.d. 28 mm [1.10"]
- 80 C working ambient
- 13 m (42 ft) (can be spliced, and exceed the nominal od)
- PTFE core
- 316 SS braid reinforced
The combination of high temperature and high pressure seems to be a bit of a problem. Google turns up lots of suppliers, but when given the details, I get a lot of "no quote".
Any ideas?
- 3/4" nominal
- PTFE core
Any ideas?
RE: Source of supply - Hydraulic hoses
Mike Halloran
Pembroke Pines, FL, USA
http://u
htt
two suppliers that helped us were Universal Metal Hose<br />
<a href='http://www.universalmetalhose.com'>Universal Metal Hose</a><br /><br />
and HFI Fluid Power Products
<br />
<a href='http://www.hfifluidpowerproducts.com'>Hydraulic Hose and Hose Assemblies</a>
<br /><br />
Good luck, if they cant help you out, you may have to try a steel tube solution.
