Help menu in Inventor not working correctly
I am trying to use the help from the drop down menu and I am having problems. When I go to the Help menu and select "Help topics", a window opens with a panel at the left and the main window at the right containing all the bulleted items. When I try to select the bulleted items, the only one that works is the first one "Sutodesk Inventor Launchpad". All the other ones result in a message that comes up reading "This option can only function within HTML help".
If anyone here has experienced this problem, please let me know if you came across a solution.
Thanks in advance for any help.
Tony Billeaud
Mechanical Engineer
RE: Help menu in Inventor not working correctly
ht
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
I have Inventor Series 11 with service pack 2 installed. No hot fixes are installed yet but I reviewed those and none are relavent to this issue. Our IT department installed the software on my system so I can only assume that virus scanners were disabled during installation.
Tony Billeaud
Mechanical Engineer
