Converting old AutoCad drawings to Models
Two part question
I have several older Autocad drawings with tooling components detailed and I'm starting to convert them to Models. Most of the drawings only have a single Top-View with notes describing the thickness. Rather than redrawing everything from scratch in SW this is my process.
1) erase all non esential geometry from original Acad dwg including notes, hatch, etc.. this is fast with filters
2) Insert dwg file into SW sketch
3) Block the entire sketch and coincident relate the block origin to my sketch origin
4) Rename this sketch as "Master from AutoCad
5) Make a new sketch and Select and convert geometry from the master blocked sketch. Then extrude it into the basic model. I will then use the Master sketch as a template to locate and apply Hole wizard holes to my model.
This isn't really too time consuming for a conversion process, and it does insure the integrity of the new SW model to the old AutoCad drawing.
1st question: Does anybody suggest a better way?
2nd question: is there a way to chain or window select geometry from the blocked sketch above? I currently have to single select each line?
thanks
Tom
thanks
Tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: Converting old AutoCad drawings to Models
No answer to question 1, but for #2:
When converting entities from the master ACAD sketch, you can pre-select the ACAD sketch (or the block) from the feature tree and then use the convert entities function. This will bring all the entities in your ACAD sketch into your current sketch where you have greater selection capabilities (window, chain, etc.).
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 03-26-07)
Q2 ... You should be able to select all entities with a window created by just dragging the cursor.
SW07-SP3
SW07-SP3
I like your approach of leaving the master ACAD sketch intact. I do this, as well.
At least half the time (for me), the ACAD geometry does not match the numbers. Occasionally, the numbers are not mathematically possible. Remodelling or reconstraining sketch is a good way to get a reality check.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
