Hole Wizard - Disable does not work when modifying hole
We've begun to use a custom hole wizard database, intended to simplify the selection process (ie, picking the correct thread for an M10 tap). We copied the ANSI metric database and disabled holes as appropriate. This works for a new hole, but when editing an existing hole, ALL of the disabled holes are shown, even with the custom standard selected. Any ideas?
Mike
SW 2007 SP3.0
Mike
SW 2007 SP3.0
RE: Hole Wizard - Disable does not work when modifying hole
SW07-SP3
Ken
Mike
