BEND INFO ON UNFOLDED VIEW
RE: BEND INFO ON UNFOLDED VIEW
I havent tested it but try this, create the 3d annotations in Functional tolerancing and annotation workbench then create your drawing. please let me know if it works
Edit (Default)GenerativeStyle.xml standard. There is a branch for Sheetmetal views. You can set UpDown status for bends visible. Bend axisline can be set there as well.
