Imbed a Jpeg image into drawing template
I have a Logo with nice shadow effects saved as a jpeg. Is there a way to imbed this into my titleblock area on my drawing template. I created a decal on a surface model but the drawing template will not save it.
tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: Imbed a Jpeg image into drawing template
I'm pretty sure, Tom, that you're going to have to save it as a bitmap first. Then, while editing the sheet format, insert/object/bitmap image. Save sheet format & template.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Thanks Jeff, I found better quality by saving it as a pcx Pain Brush file then inserting the object.
This worked well
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Rob, When in my drwdot file I can not do that, or maybe I'm doing it wrong!! I get a message "The item on the clipboard cannot be pasted here"
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Open the logo in a graphics viewer
<Ctrl>C on the logo
Open a new drawing
Select the sheet format you want to add the logo to
RMB select Edit Sheet Format
LMB click in the sheet format and <Ctrl>V
Position & resize to suit
File > Save sheet format (slddrt)
File > Save as new template (drwdot)
cheers
SW07-SP3
Maybe insert the image into a word doc and then embedding the word doc into your sheet format. A lot of our customers do it this away. But some just embedded the image too.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
Use irfanview - www.irfanview.com - as your default image program (best quick handling, format conversion, resize/resample, batch, crop, open source image tool out there). I use this tool all the time to do quick Alt Print Screens of Solidworks with a control V in irfanview, followed by a mouse select crop and a quick ctrl s save out to jpg. But back to your logo, Ctrl C it in irvanview and go into SW and edit sheet format. Ctrl V it into the format, size and place it. This is saved in the drt file as CBL mentioned and is not held in the dot.
Thanks all for your help.
tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
