Variable section sweep problem
Hi all,
I am working on a variable section sweep, & origin curve depends on another curve defined in another graph (profile).
Everything seems ok as after I input the relation, the section size changed to match the initial graph y value.
However, it doesn't reflect the variation in cross section, when it goes along the datum curve. Only at start point. Do I miss something?
I wonder if I need to match the parameter value between graph feature & VSS feature to get the relationship. Or something else? Any idea?
engmechs
engmechs
RE: Variable section sweep problem
sd4=evalgraph("graph1",trajpar*5)
whatever your graph and dim are....
the trajpar* part has to equal your graph length
do a vss on a rect. with the top adding on your graph sweep
and then change the "* length " part of the relation it will make it clearly than I can say it
engmechs
