Breech Lock Type Exchanger
are Breech lock type exchangers totally different with shell and tube heat exchangers or from the same family?(why?) are this type suitable for use in Hydrogen Cracking Unit? which companies have a wide and proved experience to produce such kind of equipments? thanks a lot
RE: Breech Lock Type Exchanger
The google search for Breach Lock brought up the owner of this device and his website, including detailed description of the exchangers using this proprietary closure device. Look-up on the Koch Heat Transfer Company's website and you have all the answers and more in there.
Cheers,
gr2vessels
As I said, all the info is in the Koch site;- however yes, the Breech Lock type of closure can be attached to a shell and tube exchanger and from the Koch site, you can see that they build this type of exchanger for high pressure and high temperature used in hydrocracking processes. Typical refinery applications are pictured over the website. They fabricate (and sell) horizontal and vertical exchangers with the Breech-Lock closures, in many configurations including shell and tube exchangers. Please follow the links leading to Koch Heat Transfer Company's site or please type in Google the name "Koch Heat Transfer Company".
Best of luck,
gr2vessels
Checkout the Hemilok from Yuba.
Click on the Hemilok Brochure for information on the closure.
http://www.yuba.com/media.htm
Could you please share with us, what is doing an electrical engineer with the assessment of suitability of Breech-Lock device on any heat exchanger? Pure curiosity!
Cheers,
gr2vessels
I2I
Check the closures offered by this manufacturer.
http://ww
rmw
http
You're too kind. That's the site gr2vessels told the OP to go to in his posts at the start of the thread.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
A senior transgression, I came in by way of the Brown Fin Tube route and it just didn't register as it had been over 15 minutes since I had read and posted the first time.
