Deviation calculation signed?
Does anyone know wheter or not deviation is supposed to be signed? To explain:
If I evaluate a surface with a single point the nominal is defined as 0.0000, and the point measurement is .001" toward the inside material of nominal. How is deviation calculated? Does it have sign (ie negative or positive value)? Please indicate a ISO or ASME standard if possible.
Scott
Scott
RE: Deviation calculation signed?
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
Scott
That being said, you can say that there is a .xxx deviation without specifying which direction. I wouldn't think that direction really matters. Either the part is within the spec'd tolerance or it isn't. However if you have to specify, I would use the above example. Sorry I can't quote a standard for you.
David
Thanks for your reply. I agree with you, though Im trying to find information in a standard that defines "deviation" and how or if it should be summarized with a sign when referencing the reporting of a profile tolerance.
For the application of such a tolerance I believe it is required to know the direction of deviation not only to report it but to actually use the information to possibly correct the problem.
I just need some documentation that supports this "school of thought".
Scott
"For both unilateral and bilateral
profile tolerances two actual values are necessarily
calculated: one for surface variations in the positive
direction, the actual value of profile is the smallest
intermediate tolerance to which the surface con-
forms. Note that no single actual value may be calcu-
lated for comparison to the tolerance value in the
feature control frame , except in the case of unilateral
profile tolerances."
This is what I was able to find. Read all of section 6.5 Profile Control if you need something else.
David
Thank you! I couldnt find the Section 6.5(c), then after carefully reading I noticed that you referenced ASME Y14.5.1M not simply Y14.5M. I am embarassed to say I did not know of the exsistance of this document. I found it on the ASME website and promptly purchased it and downloaded it.
Thank you again for pointing it out. This will most likely suffice in my quest to put this issue to rest.
Scott
David
