draft question?
draft question?
draft question?
Hello!
I have few ribs with uniform thickness 1.5 mm in my model. (the shape of rib is similar to U shape except there is a flat edge at the bottom with end corner)
Now, I would like to apply draft but not getting success.
I tried to create a sketch with draft angle & did work but there is 35 mm radius at the 2 corner of rib. Due to 35 mm radius, I ‘m loosing the thickness from 1.5 mm at the 35 mm radius & hence, facing difficulty to apply edge fillet on the side of rib?
Any suggestion?
RE: draft question?
Please refer to the help documentation.  This is a basic task covered in very good detail.  I'm sure that if you take the time, your question will be thoroughly resolved.
Catia Design|Catia Design News|Catia V5 blog
RE: draft question?
Can you be little bit more precise, like you wanted me go through draft/edge fillet on v5 or something else?
RE: draft question?
Quote (par1):
Sorry, I thought that your question could be answered based on this statement.  I would still refer you to the docs, because what you are describing sounds like a methodology problem.
Are you trying to apply the draft BEFORE the fillets?
RE: draft question?
First apply the draft & then apply fillet,
That's always true for plastic part, Isn't it?
(1) I'm trying to solve the mystery why I'm loosing the thickness at the corner ? (I used the draft version of sketch, extruded & then  applied 35 mm radius at 2 corner & lost the thickness. Due to lost in thickness (less than 1.5 mm)so couldn't apply the fillet 0.75 mm at both side of rib )
(2)Due to the U shape of rib, I couldn’t apply draft after simple non drafted version of sketch, extrude,& applied draft but didn't get success to apply appropriate draft.
(Definitely, it its simple solid box than there is no issue to apply draft)
RE: draft question?
If you want the whole edge to be rounded can't you use a face to face fillet instead of two edge fillets?
Or maybe I'm not understanding the problem correctly.
Oh - if you don't want to loose thickness at the end of your ribs, you need to define that as your neutral plane in the draft command.
--Jay
RE: draft question?
Quote (par):
Yes, but experience in online forums teaches us that we never assume the person asking the question is utilizing the correct method. smile
It would really help if you could post a screen shot.  Your question would probably get answered almost instantly if you could do that...
RE: draft question?
I haven't send any screenpost yet so can you tell me how to do attachment?
