Quick acting and high cycle valve
A customer of ours has an application requiring quick acting and high cycle valves.
Valves will be 1", product is up to 6000cp viscosity, about 8.2 gal/min, cycling on/off 48 times/min (so quick on/off action is desirable also) for 24/7.  This is almost 1 million operations per week.  One of the products has calcium carbonate in it so we're also concerned with abrasiveness of the product.
My first thought is a solenoid valve.  Any other ideas?  My experience is in process, not manufacturing, so I've never run across something like this.
______________________________________________________________________________
This is normally the space where people post something insightful.
RE: Quick acting and high cycle valve
You might consider using an air operated pinch valve.
http://www.redvalve.com
Yes, controlling the flow sounds like it would make more sense than ON/OFF in this case.
Barring that perhaps multiple valves in parallel to distribute the cycles across several valves.
BTW that's only 1/2million cycles a week.flush
Keith Cress
sed2developer
Magnetic valve is a solenoid valve. The main problem here us the 24/7 the sealing face may not hold for long time.
controlnovice
One very impotant info is missing - the differential pressure across the valve orifice.
It pays to read the post properly! Thanks for picking that up israelkk.
Kaye & McDonald (Now part of Cashco) offer a dome-loaded valve with polyurethane (Poly-U tm) seals.
The polyurethane is abrasion-resistant, and the valve is very quick-acting.  There is not much inside the valve to be abraded.  These are the valves that they us on the "dancing waters" fountains because they are so quick-acting.
If you want to be a bit more conventional, you could look at a Worcester ball valve with a hardened ball and Ultra-High Molecular weight polyethylene seats.  The UHMWPE seats are very abrasion resistant and the Worcester actuator has been documented in low-load high-cycle applications to go as many as 14 million cycles.
At a million cycles per week, even a 14 million cycle valve will only last a few months.
Parallel valves (maybe 2 or 3) would allow cycle distribution, and an easy way to replace valves.
Regardless of how good a valve is, after 14 million cycles, you will need to replace something.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
