Change text style globally
We receive a fair amount of AutoCad drawings from outside sources that we would like to use for xref's. However, the fonts are all over the map and we would like to be able to change the fonts to our company's standard, but we'd like to be able to do it with as much ease as possible. Is there a way to change ALL the text of one style to another style, without having to change each piece of text individually? We are using Architectural Desktop 2004 and will be changing to ABS2007 within the month.
Thank you.
Thank you.
RE: Change text style globally
select the text, mtext with "_qselect".
Maybe you would find a lisp.
Lothar
ADT 2004
how did you work?
http://
Lothar
ADT 2004
____________________
Acad2006, Terramodel
