"Program Exception:Access violation" Error in Algor
Hi All,
Anybody know the reason for an error with an MES analysis that looks like this in the ALGOR window where we track timesteps and covergence ?
forrtl: severe (157): Program Exception - access violation
Image              PC        Routine            Line        Source
apak4.exe          005E1D24  LOOKBLK                   132  outin.for
apak4.exe          005E1BBC  OUTIN0                     94  outin.for
apak4.exe          0058F82B  SETUPMMF                   86  mmrf_ini.for
apak4.exe          007B9E29  FMAIN                     292  YAPAK4.FOR
apak4.exe          00486048  MES                       170  FALLOCN.FOR
apak4.exe          008BEFF9  Unknown               Unknown  Unknown
apak4.exe          008B08B3  Unknown               Unknown  Unknown
kernel32.dll       7C816FD7  Unknown               Unknown  Unknown
Thanks in advance
RE: "Program Exception:Access violation" Error in Algor
That could be many things.  The file apak4.exe is the MES solver executable.  I'd contact Algor tech support.  Almost anything could have caused your error.
-Brian
I'd expect Algor to be very keen to replicate this problem as it reveals a bug in their Fortran source code !
I do not think this is a registry problem.  It is a bug in Algor and I find them all the time.  Re-installing will not help.  Algor has to fix this.
I agree it is a bug, but it is related to the registry.  I've seen this dozens of times.  One of Algor's tech support guys even wrote a subroutine to re-register the .dll's.  That subroutine shows up in the newer versions of Algor, so I haven't had the problem with v.19 or 20, and I didn't see this particular problem prior to v.16.  apak4 seems to have the biggest problem with it...I presume they found the problem prior to the latest couple of releases.
Mechy20, has this happened in v.20?
