Controllogix ---> EthernetIP ---> Red Lion G3 ---> Doesn't work
Hello all,
I am trying to get a Controllogix PLC to communicate with a Red Lion G3 touch screen via Ethernet. There are step by step instructions to follow in the attached link, but I am not able to get the PLC to talk to the Red Lion.
htt p://www.re dlion.net/ Support/Te chNotes/Hu manMachine Interface/ TNOI17.pdf
See page 4 of the link - I successfully install the module into the backplane and enter the IP address. When I add the "sub-module" Ethernet-module G3-HMI and run the PLC, the "sub-module" faults out and gives a Connection Request Error.
I can ping the Controllogix with success, but I can't ping the G3. I can use all the help I can get on this one.
Mike
htt
Mike
RE: Controllogix ---> EthernetIP ---> Red Lion G3 ---> Doesn't work
I looked at the documentation and it looks correct. We make a n Ethernet/IP compatible product that we know works with both the Red Lion and the Rockwell Control Logix. There shouldn't be any problem as long as you get the subnet and masks correct.
As for you last question, I configured the G3 exactly per the instructions in the link.
