Anti Virus and install problems
Anyone having any real life stories about NOT turning off the anti virus and installing without any problems? I'm discussing this matter, due to the fact we are seeing all sorts of bizarre little problems since updating to 2007, and IT did not turn off the Anti-Virus. I'm tired of arguing the issue. Thanks,
John
John
Certified SolidWork Professional
CAD will not make better designers; it will only make poor designers faster...
RE: Anti Virus and install problems
We just had a guy in from SolidWorks last week. The first thing he told us was to make sure any virus software is turned off.
SA
Listen to them, always shut it off!
John
http://
SW07-SP3
I was planning on using the search yesterday, but it was under maintenance. And I was frustrated enough, that I had to start the thread. It's tough, when people that know it all, don't....go figure?
J
My post was not a suggestion that you should have done a search. I knew the search function was offline. I was just stating that other threads had reported that a faulty install turned out to be the cause of their problems.
SW07-SP3
sorry if you took it that way. I was really refering to internally here. It's a complete flux though, somedays are worse than others. For most part it's okay, but these type of senseless arguements with IT are not needed, for a guideline that SolidWorks and other companies use.
I've always valued your input on this forum, and again sorry if the text was a little vague.
Later Cor,
J
SW07-SP3
If they don't follow this then they are to blame as you already know. If your IT does not listen i would take up with a higher person then them... maybe the VP or the President of the company... I would keep moving up the ladder to something of higher authority then them... who cares if you make some people mad... they should have listen to you in the first place. Your there to work not make friends.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
Bradley
SolidWorks Professional x64 2007 SP3.0
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
Virtual memory 12577 MB
NVIDIA Quadro FX 3400
I've had several subscriptions of McAfee and Norton--until I finally wised up and read extensive reviews of other possibilities. Unless something changes rather drastically, I'll not use either of the above-mentioned again. They're terrible resource hogs and not entirely effective at what they claim to do.
As it stands now, I use Avast Pro for AV ($40/year) and the free ZoneAlarm for a firewall with no anti-spyware stuff. The result is very little resources lost to system protection (see how much this stuff robs of RAM and processor use). The last bit there was a decision made after using a combination of three free anti-spyware applications over at least a year of time. I then noticed the resources they used to do their jobs, and uninstalled them. Just to check, I reinstalled and ran the software several months later and my system came up clean. I don't seem to have a problem without the software on the machine, so I don't use it.
More to the point of this thread, I've not had buggy installs as a result of AV being on during the install--but I don't leave it on, either. When I do have a problem, I normally opt for a clean install with registry cleanings and reboots during the process to make sure I don't have any corrupted stuff left over. I might note that I put commonly accessed documents out of my Program Files folder to a neutral (non-erased) location on a separate "files-only" hard drive so I don't encounter problems in reinstalls, such as data loss (templates, PhotoWorks materials, decals, scenes, and other items).
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
