Sketch projection
Sketch projection
Sketch projection
I tried to search the forum but no luck (I admit I am NOT very good at that).
I have a sketch on Front plane and another plane at an angle to Front plane.
I want to project the sketch from the Front plane to that "angled" plane but the "projection" to be perpandicular to the Front plane, NOT to the "angled" plane - so if Front plane is parallel to the screen, both sketches are on the top of each other.
So far I found that I have to create a Face (SurfacePlane) on that "angled" plane and than use Curves - Sketch onto Faces to project the original Sketch, plus hide the SurfacePlane.
I wonder if I could do it in fewer steps ??
RE: Sketch projection
Again, forgot to say SW2006,  SP 5.0
After creating your initial sketch on the front plane, you could use copy/paste on this sketch and then link the dimensions between the two sketches.
Creating a surface from the sketch and using a body move/copy with a convert entities isn't a bad a approach either. If your initial sketch may be subject to major changes I would use this method.
RFUS
I think that's about the quickest way.
Can you explain more what your end goal is? Maybe there is another method to achieve it.
cheers
SW07-SP3
CBL
Converting AutoCAD Weldment into SW Casting.
Detail plates (Flame Cuts) are welded "at angle" but machining is done at 90 deg to Front Plane.
Anyway, it looks like I was on the right track and I can handle it - perhaps even without that "perpandicular" projection after all.
Thanks for the answers.
You could also extrude your initial sketch (either as a solid or a surface) to a distance that completely intersects your angled plane and then create a sketch on your angled plane that's totally comprised of intersection curves between the extruded geometry and the angled plane.
