Laser Tape Measure
Laser Tape Measure
Has anyone used or know of a laser device that one person can use to get accurate measurement of pipe and supports for hard to access pipe systems.
Thanks for your replies!
RE: Laser Tape Measure
Forums > Civil / Environmental Engineers > Activities
Surveying & Geomatics Forum
When you find out what it is called, please consider trying here. In full disclosure, they are part of the Parent of my A/E firm; but I do not directly benefit from your shopping here:
http://www.firstpointsurvey.com/
Signature under construction, sorry about the mess - Steve
http://www.hi-cad.net/
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
try here
h
or here
http://www.opticsplanet.net/rangefinders1.html
I bought mine at Sears Hardware. It works pretty well, but it has a range limit.
A Leica - "Ultra High Speed Laser Scanner"
http://ww
BigInch
Glad it's not just me. Met a gent the other day, chatted with him at lunch. Saw him again the next morning and completely blanked on his name. The short term memory goes first they say...if I can just remember who "they" are...
Seriously though, laser scanning has many advantages, one of them being objectivity - assuming that the setup laser guys are well-trained. You end up with a "data cloud" (think connect-the-dots) which can be imported into various 3D CAD piping programs. Very nice, but relatively expensive at the outset.
Remember that the quality of field measurement often depends on the crew's experience and the ambient weather. Frozen fingers don't hold a plumb bob or tape measure very well.
Good laser pointers, paintball guns and many photos from different angles might be an on-the-cheap solution.
I think Disto is one manufacturer of laser measuring devices. Just make sure your measurement guy is a knowledgeable piper or you might end up with dimensions to something irrelevant:
Measure Guy: "Look, I followed all the manufacturer's instructions, twice, just to make sure!"
Field Guy: "Then why is the tie-point 6 5/16" off?
Measure Guy: "I dunno, I made sure I was lined-up X-Y and put the laser spot on the 'pipe' wall."
Field Guy: "Was the laser spot on something shiny?"
Measure Guy: "Umm, maybe. But I'm SURE it was the pipey thing I was supposed to shoot."
You could check out h
