Steam reducing station
I hope this is the right forum for my question : its about a pressure reducing station in a steam line;I have a 12" steam header 300 ASA with op temp at 210°C and flow rate = 25 T/h at 13 barg.I need to reduce to 10barg and provide the same mass flow Can someone give me some advice as to what I need for this and also recommend a supplier.The project is in the Netherlands.Thanks
RE: Steam reducing station
My rough calculations indicate about 587 liters for desuperheating low pressure steam. So, you will get 587 kgs of extra steam.
Here are some contact details, all three should be able to advise you on what you need.
www.spiraxsarco.com/be/DUT/
www.Gestra.com
www.samson-regeltechniek.nl/
