Expressions not updating.
Hi, I'm a new menber here and I'm having some trouble with expressions not updating the 3d model in Nx3.
I'm converting 350+ drawings from UG into Autocad using the 2d exchange function.
The UG data is set up to modify the 3d model to part processing conditions using expressions. This was done with a proprietary software package that is no longer supported by my customer.
I have all the required data, I know the proper syntax to use when setting the suppression level in the expression window. After I click apply or ok, the model acts like it is updating. The information line tells me it's updating various part features and the model regenerates. When finished, there are no changes to the model.
Any help or suggestions on this are appreciated.
Ed
