How do I create an STL file?
I need to create some .stl files, but don't see the file extension under save. Do I need a special license?
RE: How do I create an STL file?
But without the lic. you still should be able to save a CATPart as a STL file. For a CATProduct, you should use the Tool in Assembly Design to turn your CATProduct into a CATPart.
To refine the STL you definitly need the STL lic.
