Programming Euler angles in MATLAB
Hello all!
     I am having difficulty extracting Euler angles from a rotated coordinate system in MATLAB. The problem comes in when the angles go outside the bounds of [-pi/2,pi/2] because the asin() function only outputs within those bounds. Does anyone have any insight into how I might be able to extract the proper angles without getting the sharp discontinuities in the plot as a function of time? I've really been banging my head on the wall for this one. I appreciate any help!
Andy
RE: Programming Euler angles in MATLAB
Build a function asin2(a,b) that correctly identifies which quadrant a given pair of arguments a and b are in.
Cheers
Greg Locock
Unfortunately, it isn't that easy in 3D. I have vectors i,j,k for a particular body, and I am trying to get phi, theta, and psi (sometimes referred to as alpha, beta, and gamma) with respect to the global I,J,K axes. There is a published work on this, but they use arguments such as asin[(IxL)*dot*K], which doesn't work in MATLAB... thanks for the try though!
I figured it out, and wrote this m-file. There is still potential for error for angles outside of [-pi,pi], but I was able to simply add or subtrace 2pi when discontinuities were present. Anyway, here is the code, in case anyone wants it...
function [PHI, THETA, PSI] = FindEulerAngles(i_SEG, k_SEG, L_SEG)
% This function finds the Euler angles of a rotated coordinate system based
% on the i, k, and L (line of nodes) values for a given segment. This code
% is supplement to the Vaughan GaitBook. The reason the formulas below do
% not match the ones given in the text is that he uses the asin function,
% which only reports values between [-pi/2, pi/2], so there were
% discontinuities and errors when the Euler angles were greater than pi/2.
% Therefore, the code below contains the formulas for several cases, which
% are explained at each angle calculation.
% IMPORTANT NOTE: This code will give incorrect results unless the vectors
% i_SEG, k_SEG, and L_SEG are normalized to 1 in each row!
I = [1 0 0];    % Define global X-direction
K = [0 0 1];    % Define global Z-direction
for count = 1:size(i_SEG,1)
    % Phi is positive if the Line of nodes (K x k) contains a positive
    % y-value
    if L_SEG(count,2) >= 0
        PHI(count,:) = acos(dot(I,L_SEG(count,:)));
    % Phi is negative if the Line of nodes (K x k) contains a negative
    % y-value
    elseif L_SEG(count,2) < 0
        PHI(count,:) = -acos(dot(I,L_SEG(count,:)));
    end
    % Theta is positive if the xy-plane is rotated positively about the
    % Line of nodes (according to right-hand rule). Therefore, there are
    % two cases that include this:
    % 1) phi > 0 and the x-component of k_seg > 0
    % 2) phi < 0 and the x-component of k_seg < 0
    if (PHI(count,:)>=0 & k_SEG(count,1)>0) | (PHI(count,:)<0 & k_SEG(count,1)<0)
        THETA(count,:) = acos(dot(K,k_SEG(count,:)));
    % The two cases in which phi is negative are:
    % 1) phi > 0 and the x-component of k_seg < 0
    % 2) phi < 0 and the x-component of k_seg > 0
    elseif (PHI(count,:)>=0 & k_SEG(count,1)<0) | (PHI(count,:)<0 & k_SEG(count,1)>0)
        THETA(count,:) = -acos(dot(K,k_SEG(count,:)));
    end
    % Lastly, the third angle is positive if theta and the z-component of
    % the i_seg > 0, as represented by the two cases:
    % 1) theta > 0 and i_seg > 0
    % 2) theta < 0 and i_seg < 0
    if (THETA(count,:)>=0 & i_SEG(count,3)>0) | (THETA(count,:)<0 & i_SEG(count,3)<0)
        PSI(count,:) = acos(dot(L_SEG(count,:),i_SEG(count,:)));
    % The other cases are:
    % 1) theta < 0 and i_seg > 0
    % 2) theta > 0 and i_seg < 0
    elseif (THETA(count,:)<0 & i_SEG(count,3)>0) | (THETA(count,:)>=0 & i_SEG(count,3)<0)
        PSI(count,:) = -acos(dot(L_SEG(count,:),i_SEG(count,:)));
    end
end
