Speaker (coil)...usable as antenna ?
For my wristwatch-sized bugdetector i need lots
of antennas on a very small space.
Since i have a speaker in there also
i wonder if i could use that as antenna
for the lower part of (HF)frequencies...allthough
it would be nice if it went up to 100 Mhz :) :)
I have not decided on wich speaker yet
But probably it´s going to be 8 Ohms,200 mW
In a plastic housing...the coil and the connections
are the only metal parts...one of these for example:
http://www.elproma.com/buzzercat/buzzer-5.html
I will have more(other) antennas for the other freq-bands.
Question 1
For wich freq-range could i use such speaker (coil)
It will not be tuned with a capacitor since i have to
detect a broad-range of frequencies.
Normally i would say it will only do the lower HF frequencies (shortwave)
Question 2
What to look for in a speaker for antenna purposes ?
wich one from the mentioned link might serve ? why ?
Question 3
I suppose the directivity/pattern will be the same as
the sound direction...something like an 8 characteristic
what can i do to make it only look outwards
...in one direction ?
Question 4
Since the speaker when also used as antenna will have
a dual function...will i have some feedback-problems ?
meaning that the received audio will make the coil
vibrate..and therefore cause feedback/oscillations ?
Simply block that with a Highpass LC-filter ?
Questions 5
Anyone have a link to an example where they
use a speaker as antenna...(no show on Google)
Or suggestions for the circuit at the speaker ?
Thanks again !
WatchJohn
RE: Speaker (coil)...usable as antenna ?
Interesting idea since it's already got a ferrite in it and alot of wire.
If you have some way to test it (network analyzer), you'd find your answer quicker than research and analysis.
kch
