Sealing (Mechanical) Suggestions for HP suction pump
I welcome suggestions, recommendations, and/or open discussions for sealing mechanisms (mechanical seal system) for a multistage HP suction (~2000 psig) horizontal split case pump and pumpage is water. Proven cases or references would be beneficial. I've ideas, but welcome others.
-pmover
-pmover
RE: Sealing (Mechanical) Suggestions for HP suction pump
Tim
I have already commenced contacting seal reps and hope to obtain references. The posting is an attempt to find if anyone else has encountered this or similar situation before. The application is hp seawater injection. Thanks for the response. - pmover
