Where's that roving clipping plane?
I used to reveal the innards of parts and assemblies in Solid Edge by means of a dynamic clipping plane and I've been told I can do it in CATIA too. Can anyone point me to it?
RE: Where's that roving clipping plane?
Yes. It's in the Assembly workbench, so you'll have insert your CATPart into a CATProduct. From there, it's the function called "sectioning." If you can't find it from the icons right away, I would suggest that you pull it up from the View -> Commands List menu item. (then look for the highlighted icon)
Catia Design|Catia Design News|Catia V5 blog
