Crawl Space Dilemma (Visqueen, water and efflorescence)
Hi there. The house is in a coastal area (west coast) with a high water table and a dirt crawl space. After taking the recommended steps to limit water under the house (sump pumps, drainage away from the house, etc.), I installed 6 mil plastic sheeting over the entire crawl space. Shortly after we completed installation, there was noticeable efflorescence on the cement piers (sides and top) and on the foundation walls (both inside and outside). After brushing off the piers, I continued to inspect the crawl space over the next week - thinking that it would taper off - but the efflorescence build-up continued. It seems as if the plastic, acting as a vapor barrier to the soil, has limited the evaporation under the house to water vapor through the concrete piers and foundation walls. I assume that the concrete structures are now acting as wicks for the water to evaporate because they are now the only possibly place for the water to go (evaporate).
So now what? Should we remove the plastic sheeting and allow natural, evenly dispersed evaporation through the soil or keep the plastic sheeting at the risk of water damage to the wood which abuts the concrete piers and foundation walls. Or, maybe there is a third option? Any ideas would be greatly appreciated!
RE: Crawl Space Dilemma (Visqueen, water and efflorescence)
