Point Problem
Point Problem
Point Problem
Hi
The point graphic selection box has disappeared when I select point from the top menu. Nothing comes up on the screen.  The command line prompts specify point, but I can't make any selection as the screen is empty. I have searched around for any tick box that might be unticked but havn't found anything.  Do I have to reload Cad again?  I am using autocad 2000.
Any help would be much appreciated.
Taffcad
RE: Point Problem
Are you trying to draw/place a point or select something?
If drawing points, maybe you just need to change your point style to a symbol that displays (Format>>Point style).
